TwinTurbo.NET: Nissan 300ZX forum - yes each ridge. other than that i would try oem belts. also
zxracer00
on April 21, 2010 at 3:07 AM
that had occurred to me, but the pulleys are relatively new
posted by pocheeyo
on April 21, 2010 at 02:48 AM
i wouldnt tighten to zero deflection. make it snug but if you over tighten you will literaly blow up your water pump, the bearing will vaporize. had that happen to me once....it really sucked. learned that lesson real quick though.
If a belt is squealing is it safe to assume it needs to be
pocheeyo
03:53:30 04/20/10
Re: If a belt is squealing is it safe to assume it needs to be
Marty1Mc
06:13:35 04/20/10
New belt...this is the 4th I've put on in 3 months.
pocheeyo
08:15:37 04/20/10
buy OEM underdrive belts... (n/m)
Paulym1111
10:00:54 04/20/10
Re: buy OEM underdrive belts...
pocheeyo
11:31:00 04/20/10
it's a mechanical issue, and not a problem with the belts
pocheeyo
11:34:11 04/20/10
Just fyi . i had that squealing problem and i finally
xteam300tt
12:18:12 04/20/10
Re: If a belt is squealing is it safe to assume it needs to be (n/m)
Madztt
19:15:31 04/20/10
Re: Re: If a belt is squealing is it safe to assume it needs to be
Madztt
19:20:40 04/20/10
Re: Re: Re: If a belt is squealing is it safe to assume it needs to be
jaidieray
20:42:29 04/20/10
im having the same problem at the moment
zxracer00
02:30:55 04/21/10
pocheeyo
02:48:49 04/21/10
yes each ridge. other than that i would try oem belts. also -
zxracer00
03:07:08 04/21/10
well the search madztt told me to look up says to tighten to
pocheeyo
03:26:02 04/21/10
pocheeyo
03:07:09 04/21/10
